98z28 with 2000 wiring harness and pcm no gauges work
I have a 98 z28 and i swapped to a 2000 pcm and harness and everything works fine except my dash cluster none of the gauges work does any one know how this issue can be fixed.I have all of the sensors from a 2000 camaro also and a 2000 camaro dash cluster.
The only gauges I really need is the speedometer and the rpm tach so how could i get those two to work, I have glowshift gauges for alot of the other sensors so those are not a problem I just need to see the speedometer and my rpms
