did 99+ pcm swap in a 98 car..no fuel guage with fuel segment
Old 05-11-2011, 09:50 AM
AutomagicLS1's Avatar
Default did 99+ pcm swap in a 98 car..no fuel guage with fuel segment
put my 2002 PCM in a 98 car I have. Everything works but the fuel guage. I have already sent my file to HP tuners and they did the segment swap with a 2002 express van file. Still doesn't work. Anyone had this issue?
Old 05-11-2011, 11:11 AM
CalEditor@PCMCalibrators's Avatar
That would be what I am hearing a lot of. I can tune the PCM correctly
Old 05-11-2011, 12:05 PM
what is it you would be tuning?
Old 05-11-2011, 12:23 PM
salemetro's Avatar
In 1998, the fuel sender output is a DIRECT connection to the instrument cluster.....it does NOT get it's signal from the PCM. There should be no need for a segment swap, unless you need the ability to "scale" the tank size for some reason to make the gauge read accurately....in which case, you'll need to change the sender and wiring to the 99-up style (PITA, as the tank and sender are different in 99-up cars). If you did not change the physical dimensions of your tank, you should not need a segment swap. Also, the sender impedance is specific to the 1998...as is the wiring.
Edit:
Now, I'm second-guessing myself (it's been a while since I dealt with mine). Let me dig through some wiring diagrams just to make sure....or, you can PM Caleditor for diagrams.
Old 05-11-2011, 01:05 PM
salemetro's Avatar
OK....my bad. Apparently, the '98 IS fed through the PCM. I got confused, as I swapped a 98 cluster into my '96, and got a bit foggy in my recollection of wiring differences.
Just verify your wiring, and get ahold of Caleditor....he'll take good care of ya.
Old 05-11-2011, 03:09 PM
just to make the 98 Fuel Gauge work on the 99+ PCM and a 99+ F-Body Calibration you need to simply enable the PWM output from the PCM and then you need to setup the output Hz to match the 98 gauge.
The Van segement is way off on all of the setting, but it does have the PWM output enabled. The Hz is almost 1/2 of the 98's
PM me for more details
Old 07-06-2011, 09:57 AM
Vetal's Avatar
Automagic, do you by any chance have 4L80 on your car? I have it, with swapped 98'->00' PCM, and now searching for the necessary bin file
Old 07-06-2011, 09:59 AM
I have a bin file for that
Old 07-06-2011, 10:04 AM
Vetal's Avatar
with Van fuel segment too? Is it possible that you share it with me? : )
Old 07-06-2011, 10:48 AM
https://ls1tech.com/forums/pcm-diagn...uel-gauge.html
Old 07-06-2011, 11:10 AM
Vetal's Avatar
Did a quick read but probably too quick... I can't change the necessary parameters in new PCM by myself, right?
P.S. Using HPTuners
Old 07-05-2020, 06:19 AM
taws6ali's Avatar
Hey guys I have a 1998 trans am :
99+ pcm
repinned 99+ engine/ body harness
99+ fuel tank and sending unit/ harness ,
I cant get the fuel guage to work. Had my computer tuned by frost and they brought up the issue to me and was told there isn't anything they can do tuning wise. I tried checking the harness but I haven't been able to get it to work any help would be great
Quick Reply: did 99+ pcm swap in a 98 car..no fuel guage with fuel segment
