New big injectors and now rpms going up and down
Im using HP tuners. I put 160 lbs/hr high imp injectors in my car and I changed the injector flow rate and now the rpms go up and down and wont idle. Even when i give it gas and bring the rpms up to about 1500, they still go up and down like crazy.
I tried messing with the idle air flow table, no results. Is there something else you need to adjust in 100 different injector tables when adding ones this big?
Rundown of the setup
370ci. 9.8:1 compression TU1 cam.
E85
Turbo - truck manifolds to a PT76GTS
Billet Atomizer 160# High Imp injectors.
40-42psi base fuel pressure.
This same tune I used on 2 different other engines similar and ran awesome. It was last used on my stock 6.0 w/ LS6 cam and 60# injectors.
I still have to hook my WB up to it and dial it in, but it wont even stay running. This tune should at least keep it running.... unless theres more to adding bigger injectors.??
Thanks.,
E85
Thanks.,
Whats the injector pulse width at idle?
Is it below the mininium pulse width the injector can run?
I realize you're running E85, but that still seems to be an oversized injector
They only list the low impedance injectors on their website
its listed as low 1.2 milisecond, you'd have to call them and see if that also applies to the high impedance ones. You should log your vehicle and see what its trying to run them at. Running them at near their mininium, isn't going to let them be very stable
You ask the injector manufactor for that number
I sent him a message.
Thanks.
well havnt heard back yet. But I got it so when you start the car it idles perfect... for 10 seconds.. then it starts going up and down again. When I first start the car and its fine the injectors are at 3.0ms, then in 10 seconds it fluctuates from 2.0-3.4ms and has a hard time staying running, smokes out the exhaust and after about 30-45 seconds it dies. and smoke continues to come out the exhaust.
If the IAC setting is dancing around
Start the scanner and go in to VCM controls
Click on the Special tab
Maneally set the IAC steps at a fixxed value
See if helps
Im thinking my base fuel pressure is too high. With the car off its 40. and when running its up to 50psi... my gauge bounces around so its hard to see... but i think too high. The aeromotive regulator is down all the way and still cant get the pressure down.
It sucks because i dont do this every day so everytime i pick up the laptop and start in on a project I have to relearn HP Tuners. The number values always screws me up in the airflow tables... like the idle air flow.. what does the numerical value of the number mean and increasing that does it give it more fuel or less? Ive fluctuated this number 15 each way and been messing with this car to get it running for about 10+ hours combined this weekend.
Right now it starts, idles fine for 5-8 seconds and then dies. If I pump the gas pedal up and down really fast it stays running a little, but if I slowly press it just fall flat and dies.
ok... I added like 25% to my VE table.. it runs, tachs up now and seems normal... except after idle. When you first start it, it idles at 700 and then slowly goes up to about 1000 where I have it set, it idles perfect for 15-20 seconds and then slowly starts going into its up and down fit. The idle then goes up and down for 10 seconds untill the car finally dies.
What is the the car doing after 20 seconds of initial start up? Does it go off of some other table? How can it run so good, and then just go into a phase after 15-20- seconds?
How can you return the fuel through the stock feed line, it has paressure in it, if you're also using it as the supply line unless I don't understand what you're doing. Did you run a new fuel line to supply the regulator and just reuse the original line for the return?
