Tune for 64' Rambler with 03 5.3 and 5 speed
I have a low mileage 5.3 with ported and milled heads a comp xtreme rpm cam
54-418-11 and matching springs
Basic Operating RPM Range 2,000-6,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 228
Advertised Intake Duration 277
Advertised Exhaust Duration 281
Intake Valve Lift with Factory Rocker Arm Ratio 0.534 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.537 in.
The engine will have an LS1 intake with Corvette return style fuel rail and the 5.3 flex fuel injectors. It will be a 5 speed Manual Tremec. Where would be the best place to get a tune for my 411 PCM with this combo? Would I need a handheld unit to install the tune or send my PCM out.
Thanks
Thanks
