OBD 1 with boost adding a fuel pump - tune affected?
car is tuned with a single Walbro and I'm adding another pump activated by boost.
LT1, 383, D1SC, 12lb, 60lb injectors, factory rail mounted regulator.
made 560rwhp on dyno - but driving it the car loses fuel pressure at WOT when boost goes up fast an toward 10lb
otherwise the tune is really nice - just falls short on fuel volume it seems.
When the added fuel comes in under boost - will the car go rich now?
will the injectors just flow it through and excess go back the return line?
how could added fuel under boost (needed) impact my tune?
I have driven it more now and may have found the pressure weakness - previous owner put a few hundred miles, thought it ran perfect - which until the fuel drops way out there at WOT - it does.
