Question about map sensor linear and offset 2 bar map hp tuners...
Old 07-31-2011, 10:57 AM
slammin86's Avatar
Default Question about map sensor linear and offset 2 bar map hp tuners...
I am tuning a camaro later today. The guy is doing a turbo build but the turbo is not on yet. He has done the heads, cam, and 2 bar map sensor from a cobalt ss (pn 12615136). I am working on a base tune and have converted to 2 bar sd. I have already done the base ve table and everything else.
Do I need to change the values in the "map sensor linear" and "map sensor offset" under engine diagnostics - airflow tab? If these change how do I know what the new values are?
Searching says...
offset = 8
linear = 200
Can anyone confirm this?
How about the P0106 error values?
Old 10-24-2011, 06:23 PM
kornboy's Avatar
i have Similar guestion on p0106
Quick Reply: Question about map sensor linear and offset 2 bar map hp tuners...
