ses Light comes on after 70mph
Old 08-06-2011, 05:19 PM
Tyler Z28's Avatar
Default ses Light comes on after 70mph
its a bolt on ls1 camaro tuned and a stall and when im driving it after about 65mph the SES light starts blinking at me and once i slow down to slower than 60 or so it stays off, i had someone tell me it might be the wheel speed sensors (i have 3.73 gears and taller tires than stock) but im not sure any input would be appreciated thanks Guys.
Old 08-06-2011, 06:03 PM
2001NBMZ28's Avatar
First step is to see what the code is. Flashing SES usually means a misfire - but could be anything. Even though it's off history codes will still be stored.
Old 08-06-2011, 06:46 PM
Tyler Z28's Avatar
well i was on a roadtrip and for 150+miles it was continuously flashing ? not sure if that helps or changes anything? it has long tube and the rear O2's were tuned off.
Old 08-08-2011, 04:36 PM
nasty_ss's Avatar
how do you know which cylinder to check when this is happening?
Old 08-08-2011, 05:59 PM
Mike Morris's Avatar
Scan the ecu-it will tell you. If you dont have a scanner go to Autozone
Old 08-08-2011, 06:57 PM
nasty_ss's Avatar
it's just blinking but pulls no codes
Old 08-09-2011, 03:48 AM
Tyler Z28's Avatar
do they scan for free at autozone?
Old 08-14-2011, 11:59 PM
nasty_ss's Avatar
yes, they should
Old 08-15-2011, 01:19 PM
revtech101's Avatar
I have seen EGR codes do this on other cars. Try to keep track of the rpm and load rather than mph. It will throw a code when cruising between 2k-3k rpms as this is where the EGR works. Drivability will remain the same. Solution may be as simple as turning off the code.
If its miss firing then you should be able to feel the hesitation. Do you?
Old 08-15-2011, 02:40 PM
ShoddyHog's Avatar
Originally Posted by nasty_ss
yes, they should
OP is in CA. I think I heard that they won't do it out there.
Old 08-16-2011, 09:57 PM
Judge Smales's Avatar
I had this happen on my 02 Chevy 2500HD with the 6.0 and it ended up being two fuel injectors that were going bad. Car ran fine but would blink the light at just about the same speed that you stated. Truck was still under warranty when it happened so they took care of it for me, but just thought I would throw that out there.
