LS1 Edit ? about VSS
Under the speedometer tab in Edit, I changed my tire size and gear ratio, but when I hit update, the VSS pulses per mile and pulses per revolution don't change. For a 29.2" tire w/ 3.73s, what should these VSS numbers be set at? I compared my file to someone else's file with the same tire size and gear ratio and he had different VSS numbers.
my numbers:
pulses per mile - 52845
pulses per revolution - 26528
his numbers:
pulses per mile - 52754
pulses per revolution - 41486
I'm having trouble getting my truck to shift into 3rd at WOT and I'm wondering if this could be a cause?
Thanks
my numbers:
his numbers:
Thanks
Originally Posted by Texas Terminator
did you change your tire size and gear ratio in the boxes to the right? did you save your file before you closed the editor?
