maf/tunning question
Old 09-21-2011, 04:53 AM
Reno's2fastestfbodys's Avatar
Default maf/tunning question
(98 camaro) is there a maf thats being used for tuning ls1's i heard that a zo6(dont know year) is a larger mm and reads true. currently have slp i know it doesn't meeter or translate real #'s.
Old 09-21-2011, 07:37 PM
joecar's Avatar
You use the stock MAF and correct it using a wideband (same procedure as you do for correcting the VE).
If you change MAF and/or duct, then you have to do the correction again.
Old 09-22-2011, 10:33 PM
and getting it to fit my setup of 85mm?
Old 09-23-2011, 02:51 AM
joecar's Avatar
Find a MAF that physically fits, then get the MAF table corrected (using a wideband),
Old 09-23-2011, 10:12 AM
Moderator
jimmyblue's Avatar
As a start get a clean Delphi MAF and use a Delphi MAF
table. You ought to be within 5% of dead-on unless you are
looking at a really big cam at low RPM, or have a crazy
bent intake plumbing right before the MAF face and no
screen.
