Map code messing with TCS
Old 09-29-2011, 05:19 PM
PAT-WS6's Avatar
Default Map code messing with TCS
Ive searched and found out the the map values under eng diag. on some cars will throw the tcs into a werid mode, Permantely making it not being able to turn on and off. When searching i found that if your idle is higher than 60kpa then you need to increase the table.
Engine Diag>Airflow> p0106 error map calculated min & max.
Ive messed with these tables on a MS4 A4 2002 WS6 With traction control, tried everything and still have the issue.
I seen on another car they maxed out the tables and that fixed it, but however it wont fix this. When the tables are maxed, it lets you turn on & off the TCS but only for about 20 miles before it goes back to permantely off.
Ive seen alot of people deal with the issue but no exact fix, anyone care to give a hand?
Old 10-02-2011, 07:00 PM
PAT-WS6's Avatar
bumppp
