MAF problems
Old 10-04-2011, 09:35 PM
kblehm's Avatar
Default MAF problems
I'm having a issue with my MAF not working. I replaced my SLP MAF with a stock one and another SLP MAF and it still isnt working. I tested the wires to make sure they have continuity and the ground does and the wire that runs from the MAF to the ECU does. I just dont know where the pink wire goes.
Ive searched the forum for the answer to my question but just cant figure out where the pink wire goes after leaving the MAF sensor.
This is a post I found in my search but I dont know where the
3 MAF power (IGN), to FBody MAF harness, PNK (pink) to ENG SEN fuse is.
https://ls1tech.com/forums/generatio...ml#post1141944
HELP!!!!! I dont want to go to SD!!
Thanks!!
Old 10-08-2011, 12:35 AM
kblehm's Avatar
Finally got the car up in the are and started checking grounds and wires and found my 02 sensor wire got alittle close to the header. I also found the Engine Sensor fuse blown and have replaced that. Hope I found and fixed the problem but will know more tomorrow.
