98 Z28 tuning problems
Old 10-10-2011, 07:25 AM
Abilene98Z's Avatar
Default 98 Z28 tuning problems
Ok I have finally got to the motor after suspension and driveline improvements. So I just wanted a cam only car. So in goes pro products 96mm intake, throttlebody, and fuel rails, walbro 255 pump, Bosch 30 lb injectors(36 lb@58psi), MSD BlasterCoils, and Tick Polluter Cam. Everything going good til tuning process. Car hesitates (damn near dies) from 2k-26 rpms then at 27ish BAM! Full power like I'm trying to launch at the track. Apparently a 98s pcm is untunable with what I gave put into the car? Can someone verify this for me? Because the only options they have given me are 1) get 00-02 pcm and re-pin it for my 98 harness or 2) get 00-02 pcm with wiring harness and install it all? As for now car is parked and that isn't cool. Any ideas please!?
Old 10-10-2011, 08:27 AM
jmm98LS1's Avatar
You've got something else going on, 98's can be tuned just fine. I make 500rwhp with a nasty cam on a 98 pcm.
Old 10-10-2011, 09:03 AM
Old Geezer's Avatar
Post the tune and a data log, and see what response[s] you get. X2 with what jmm states..
Old 10-11-2011, 05:55 PM
Abilene98Z's Avatar
Thanks guys I'm just waiting for the tune and data logs and ill post them asap
