Tuning issue or injectors?
Here is my dyno graph from Saturday with the A/F ratio on it. It is kinda wavy, but what concerns me is right there at the end, where it goes lean at the HP peak. Do you think some Edit tuning could tweak that, or is my stock 2002 injectors just "used up" at that point?
Could be the injectors are going static but you should log the pw just to be sure. BTW IMO 13.0 AFR is not "FAT". You do have a valid concern running close to 14.0 AFR at 6500 rpm.
Greg
Greg
doesn't look that bad. maybe getting a little lean at the end. do you know what your duty cycle is like? have you tuned the car? have you changed the pe/rpm table?
Originally Posted by GrapeApe
i guess check out the duty cycle with atap
