98 ecm on heads/cam car idles high - sometimes
Ok, I figured id throw this thread on here and see if anyone has any ideas about it. Im running a 98 ecm in my 98 z28. Its a new ecm. Basically a stock short block with ported heads and 236/242 cam. Now, I purchased the car a few years ago, and with the tune it had on it from TSP, cam only, it would idle high when I reached stop lights. This is only intermittently. I wrecked the car last year, and after building it back to it's former glory, installed ported 5.3 heads on it. I had it tuned by a different shop, and even installed a brand new 98 ecm. Now, it acts the same way. Im thinking it's just the fact that it's a 98 ecm, as I've heard they are inferior to the 2002's. I've checked for vacuum leaks, I know the throttle body is adjusted correctly, and the IAC is new. The spark plugs are a bronze color, and as far as I know, the tune is up to par from looking at the dyno numbers. Any opinions would be greatly appreciated. Thanks!
Ok, thanks for the input. When I'm able to get my buddy with EFI live over, I'll have him make a copy. I'm assuming the timing is pulled back a bit though, the highest we have around here is 91 octane. When I start the car for the first time in the morning, I can hear the IAC sucking in air, and the rpm's lope up and down a bit, but eventually even off.
