Auto Meter Tachometer install on LS1 12200411 pcm
Old 10-22-2011, 09:35 AM
BOLO's Avatar
Default Auto Meter Tachometer install on LS1 12200411 pcm
I don't know if this is the right section for this specific tech question, but any info is appreciated. I did the LS1 pcm conversion for my LT1 and wanted to wire my AutoMeter#3980 tach. Since I'm now running multiple coils, what cylinder do I set the tach for?(involves cutting some wires back of tachometer)And where do I get tach signal from? Any suggestions is greatly appreciated. Thanks.
Old 10-22-2011, 12:27 PM
fastgmc98's Avatar
I usually just hook up green tach wire to PIN#10 on Red PCM connector...
Never had to cut any wires...
Old 10-22-2011, 05:49 PM
BOLO's Avatar
So, the tach is then set for 8 cyl? 4cyl? 6cyl? Need more info here
Old 10-23-2011, 04:41 AM
Doubledip's Avatar
4 cyl
Old 10-23-2011, 10:08 AM
BOLO's Avatar
Thank you. 4 cyl it is.
Old 08-05-2012, 01:22 PM
408tony's Avatar
How do you set it for 8cy or 6cy or 4cy?
Old 08-05-2012, 02:14 PM
oange ss's Avatar
should be DIP switches on the back of the tach to set the cyl mode
Old 10-07-2012, 08:12 PM
BOLO's Avatar
Just an update info on this. I did not have to cut or adjust anything on the back of the 5" tach #3980. Works flawless.
Old 10-11-2012, 08:26 PM
LS1MCSS's Avatar
A lot of Autometer tach's have two wires looped out the back of them. Depending of what cylinders you want it set for determines if, or how many of the wires have to be cut apart.
Quick Reply: Auto Meter Tachometer install on LS1 12200411 pcm
