What would make idle 25 higher than set value?
I have programmed the car to idle at 825 and it refuses to do so. It will idle 850 +/- 10 rpm. I had it at 875 and it idled at 900. What could be cause the pcm to make the idle value higher. Values are check by autotap. Thanks.
John
John
Originally Posted by John02SS
I have programmed the car to idle at 825 and it refuses to do so. It will idle 850 +/- 10 rpm. I had it at 875 and it idled at 900. What could be cause the pcm to make the idle value higher. Values are check by autotap. Thanks. John
joel
Originally Posted by Bink
The set Idle value is a target for the PCM - not an absolute. You might try reducing your IAC value (a small amount) which will reduce airflow at idle. What are your IAC and RAF tables set at 40*C and up?? Alternatively, you could reduce timing advance a couple/few degrees at 1200 ->800 RPM. Hope this helps some.
joel
joel
