EFI live questions
EFI live questions
My brother just recently purchased EFI live, and im wondering what we will be able to tune on this setup:
2002 Chevy 5.3l
no egr
no evap
no vats
Manual trans
just a basic stock 5.3l at the moment.
would i need to get Wide Band O2 sensors? i just have a set of new BOSCH bought from napa.
im just trying to see if it would be worth it for me to buy a vin license for it.
also, ive heard that without putting a cam in it, you can decrease timing at idle and get a lope that way? is this true? or is anything like this possible?
Thanks
2002 Chevy 5.3l
no egr
no evap
no vats
Manual trans
Thanks
It wold be worth it just to turn off all the emission codes for the things you removed. Also adjusting trims to get back in line will help fuel mileage. Then you can play with the timing some to get a bit more power and economy. As for taking out timing at idle to make it run rough just makes no sense to me. Why make you engine run like **** just to make it sound cool. Even at that it will no way sound like a cammed engine.
2002 Chevy 5.3l
no egr
no evap
no vats
Manual trans
Thanks
2002 Chevy 5.3l
no egr
no evap
no vats
Manual trans
Thanks
Your Bosch sensors from Napa are stock narrow band sensors that the vehicles pcm can translate. A wideband is something totally different. You don't NEED to buy a wideband 02 sensor unless you plan to tune WOT sections of the tune. In my opinion YES you want a single wideband 02 sensor so you CAN use your tuning software for its full purpose.
Yes you can practically shut the car down to a fluttering trickle of cam like hickups (or blow it up even) using the EfiLive software. This ain't no handheld!
My recommendation: Don't touch anything. Go READ for atleast 6 months...then start tuning.
