IAT harness
Old 11-20-2011, 08:18 PM
sunset_Z28/RS's Avatar
Question IAT harness
I have a SD tune on my car and i need the harness to remove the MAF and hook up the IAT only. I have been searching and cant find it
Old 11-20-2011, 08:34 PM
fastgmc98's Avatar
http://www.eficonnection.com/eficonn...spx?ItemId=294
Old 11-20-2011, 11:01 PM
SATAN's Avatar
Yeah, I didn't think there was a sub harness for that. I was pretty sure you just had to find the wires that come from the PCM for the IAT and wire it in yourself (which is what I'm doing).
Old 11-21-2011, 02:35 AM
Actually there is one but it's in Australia don't wanna wait for shipping lol
Old 11-21-2011, 09:31 AM
Moderator
jimmyblue's Avatar
My IAT is relocated using a Digi-Key thermistor for the
sensor and a couple feet of scrap wire. If you want OE
type equipment then any Firebird / Camaro in a boneyard
has your IAT pigtail. Most likely Casper's has something
too, or you could just get the Metri-Pak connector from
WayTek (body, pins, grommets all ala carte with minimum
quantities).
Old 11-21-2011, 01:58 PM
Thanks I will check them out as well
Old 11-21-2011, 02:01 PM
OnyxY2KSS's Avatar
Is this what you're needing...
http://www.thunderracing.com/shop-by...rness_985.html
You want to go from the combo maf/iat sensor to just an IAT sensor, correct? You can simply cut off the maf pigtail if you are staying SD or just zip tie it away.
Old 11-21-2011, 04:14 PM
Ok I didn't think I could use that harness because I'm going to take the MAF out completely and just use th IAT in a piece of pipe in place of the MAF. I just want it to look good not some hack job
Quick Reply: IAT harness
