c0056 code? help please
Old 03-13-2004, 12:25 PM
Greg Fell's Avatar
Default c0056 code? help please
I installed my old 10 bolt back into my t/a after taking out the 12 bolt. I now get the code...
C0056 Rear Wheel Speed Sensor Circuit Range Performance (3 wss)
I have replaced the sensor that mounts on top of the differential housing. Any ideas would be greatly appreciated.
Old 03-14-2004, 11:11 AM
Greg Fell's Avatar
ttt anyone? i'm selling the car and need to get this fixed.
Old 03-14-2004, 12:22 PM
Greg Fell's Avatar
I clear the code, and with the back end jacked up put it in 2nd gear and do not get the code. I then let the car down and drive it, and get the code after it gets to about 7 mph or so. Help please!
Old 03-14-2004, 02:04 PM
Greg Fell's Avatar
More info...if I clear the code, idle out 1st gear, the 'low trac' light comes on. I then give it just a minute amount of gas, and the abs inop light comes on.
Old 03-14-2004, 06:50 PM
wrencher
wrencher's Avatar
Was this the same rear out of the car originally?
It is either a bad connection or the sensor is unable to produce a strong enough wave form,(a/c voltage signal) for the ABS controller to use.
It was fine with the 12 bolt correct?
Old 03-14-2004, 10:06 PM
Greg Fell's Avatar
Its the original rear out of car. I have tried 2 sensors. It does not happen when the car is jacked up at any speed.
Quick Reply: c0056 code? help please
