P1639
Old 12-08-2011, 09:49 AM
clunker's Avatar
Default P1639
WELL HERES A LINK TO MY OTHER TOPIC IN THE TRANSMISSION SECTION.
https://ls1tech.com/forums/automatic...-did-i-do.html
IF IM GETTING A P1639 CODE AND THE PCM ISNT COMMUNICATING WITH THE TPS YET THE WIRES TO THE TPS ARE GOOD AND I REPLACED THE TPS WITH A NEW ONE. IS THERE ANYTHING ELSE I CAN CHECK BEFORE RESORTING TO A NEW PCM?
Old 12-08-2011, 12:41 PM
joecar's Avatar
Have you tried working thru this: http://www.gearchatter.com/viewtopic8657.php
Old 12-08-2011, 04:30 PM
clunker's Avatar
All ive done is check continuity between the tps plug and the connector on the pcm. That diagram kinda confuses me to be honest. I printed it out anyway and ill get one of my buddys to give me a hand. Thanks for the link.
Old 12-09-2011, 12:42 AM
clunker's Avatar
got it fixed! turns out i grounded out the 5v reference wire that goes to the fuel pump when i was bolting the exhaust hanger to the floor. all better now. thanks for the help. appreciate it.
Old 06-01-2012, 04:02 PM
luigiandme's Avatar
Sorry to bump this thread after 6 years. This is only for people looking to figure out this code other than being the exhaust hanger. Try checking your wiring harness behind the ECM. A smaller group of wires in black conduit will be coming out of the firewall on the passenger side. Remove the ECU to gain access. There's a self tapping screw that this harness may have rubbed through. Open the conduit and repair wires if necessary and secure harness away from screw!
Old 06-01-2012, 05:35 PM
Old Geezer's Avatar
Are you on the bong?? This is the same post you made in another thread...
6 yrs???
Quick Reply: P1639
