cartek c5r 427 readiness test
Old 01-02-2012, 08:28 PM
denaliz1's Avatar
Default cartek c5r 427 readiness test
Hey guys i'am kinda new here
i'am trying to get my 02 Z06 with a built Cartek 427 through the OBD readiness test
the car needs to have the cats installed for visual.......the rear 02's have been disabled.
i did a SMS test with efi live autocal, some results say ....not supported
will i pass , in my area i'am allowed 1 not ready and the only look for cats
any suggestions would be awesome
System Readiness Tests Results
MIL Status MIL_OFF
Number Of Emission-Related Trouble Codes 0
Misfire Monitoring Ready
Fuel System Monitoring Ready
Comprehensive Component Monitoring Ready
Catalyst Ready
Heated Catalyst Not Supported
Evaporative Purge System Not Ready
Secondary Air System Ready
A/C System Refrigerant Not Supported
Oxygen Sensor Ready
Oxygen sensor Heater Ready
EGR System Not Supported
File Type: txt
Old 01-02-2012, 09:06 PM
roughneck427's Avatar
You must be in CA??? if not supported it means its not there kinda like you dont have an EGR valve it says not supported. The rest valid monitors are set besides the evap which you allowed one anyways.
Old 01-03-2012, 05:44 PM
SSPerformance's Avatar
it will pass ...
Old 01-03-2012, 06:21 PM
wait4me's Avatar
Just install the cats and you should be fine. Just dont Reset your codes, do a flash, or undo the battery, That will reset the readyness tests, and you dont want to do that. Just let it drive and do the tests and you should be fine.
Old 01-03-2012, 06:46 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
if you want to just setup a "smog" tune just for the test..... go in and turn off all the emissions codes you can see in the tune, this will set all the readiness tests to complete.... then when the test is over turn on all the needed codes........
Old 01-04-2012, 12:06 AM
denaliz1's Avatar
thanks guys, i knew i come to the right place for info
this is , the best ls powered place
