07 TBSS LS2 dead throttle randomly
Ive been having an intermitten issue with electronic throttle on a 07 TBSS LS2 lately.
Every since ive started tuning this thing there has been a "dead" throttle randomly while driving or taking off from a stop. I reflashed the stock tune and it will still do the same thing. It doesnt matter if the vehicle is warm or cold...
ive been logging ETC pids with HPT and when this happens I can floor it and not have it respond at all, its been bad enough to where i will have to pull over and wait for it to respond again, which will take a couple minutes. The ETC% value will still read a constant 23% when this occurs (which is not touching the throttle)
No codes appear
The vehicle only has 30k miles on it...
No codes appear
Either bad TB or bad pedal. Since you said you flashed the stock file back in and it did it, then that what it looks like. Sometimes when you go to taking out the TM, you can get in trouble with the TBSS stuff and change the wrong table and it will not like it. Try taking the batt off and putting it back on and see what happens after that. The TBSS's are a finicky group.
