Quick Question
Old 03-21-2004, 08:18 PM
mbrZ28's Avatar
Default Quick Question
Does anybody know if there is a fuse for High beams, mine quit working and the bulbs are fine, I checked the fuse block and didn't see on labeled for HI beams.
Old 03-21-2004, 08:30 PM
wrencher
wrencher's Avatar
No same power source for high & low beams.
The dimmer swich is likely a possible problem, does it seem to work correctly?
If you screw around with the lever does it flash them on for a second?
Old 03-21-2004, 08:39 PM
mbrZ28's Avatar
The high beams dont work at all not even for a second, Maybe Ill hook a mutimeter up to it. Anyone know what voltage reading I should have??
Old 03-21-2004, 08:47 PM
wrencher
wrencher's Avatar
It will have 12 volts (approx) at the terminal,& 12 v on the the other for low beam, & the 3rd is a ground.
Old 03-21-2004, 08:53 PM
mbrZ28's Avatar
Thanks Man, Ill check it out.
