hpp3 strictly for tuning Torque Cnvertr
Old 03-22-2004, 09:34 PM
heyitsTaJay's Avatar
Default hpp3 strictly for tuning Torque Cnvertr
Have you used HPP3 just for tuning your car after TC install?
Was it enough for you or did you need more tuned?
I am considering using it just for shift points and rev limiter and thats it.....I would like to see who else has used it just for this and thats it.
Old 03-22-2004, 09:39 PM
LS1TECH Sponsor
Magnus's Avatar
You would be able to tune your WOT properties, but if you wanted to tune for driveability shift points and TCC lock-up points, I don't believe you can do that with a hypertech.
If your converter is on the samller side you should be ok with an HPP3.. If your converter is on the larger side and you want to do some driveability tuning, then the HPP3 will not work for that imho.
Old 03-22-2004, 09:55 PM
its a vig3200, but will stall closer to 3800. u can change shift points with hpp3. i think? also the WOT properties are gonna be changed....is this good or bad?
Old 03-22-2004, 10:05 PM
LS1TECH Sponsor
Magnus's Avatar
With an HPP3 you can change your WOT shift points to keep you from hitting the rev limiter.. I don't believe you can change your part throttle shift points though.
Old 03-22-2004, 10:14 PM
O! i see what ur sayin. got it now. think i should get the HPP3 if i can get a deal on it? i dont have $$ for ls1edit. is it REALLY important to change WOT shift points or dont mess with tuning and just drive it?
Old 03-22-2004, 10:26 PM
LS1TECH Sponsor
Magnus's Avatar
There are other tuners out there besides ls1edit.
It really depends on the price you can get one for.. if the price is right, anything can sell.
If you put the converter in and you are not hititng the rev limiter on any of your shifts than you're good to go.. but sometimes adding a looser torque converter can cause cars to hit the rev limiters on shifts, thus needing fine tuning.
