need help id'ing some connectors that are in the loom for the trans....
hey guys, i forgot to label these connectors when i pulled the engine/trans. are these all for the 4l60e? if so, can they be cut out all together since i've swapped to a th400? thanks!
ah yes, i think you're right about that. i think i did have another o2 sensor there. the car has 3 of them come to think of it now so that must be it. good call on the 2 pin one, i'm sure that's what that is.
so any reason i shouldn't delete all the wiring associated with the large round plug?
