tunerpro rt and data logging 95 lt1
Old 03-29-2012, 06:30 PM
puddingmmmmmmmm's Avatar
Default tunerpro rt and data logging 95 lt1
I'm having an issue with tunerpro rt and using data logging. While I'm recording, or when I'm playing a datalog back my information just skips around. For a couple seconds it will read normal, then for a split second everything changes, then goes back to normal for another few seconds, etc. I was wondering if this is a problem with my car, or a problem with the program or cable? I'm using a the moates cable. I could send someone a data log if needed.
Old 03-29-2012, 10:11 PM
joecar's Avatar
Try here: http://forum.tunerpro.net
Old 03-29-2012, 10:19 PM
gregrob's Avatar
Actually, just read my thread. Theres a fix on there...
Mine is smooth as silk
Basically you need to add a delay in the data stream near the header of the .adx file.
Old 03-30-2012, 02:48 PM
Thanks
Old 03-30-2012, 06:10 PM
LSxPwrDZ's Avatar
I use EFILive V4 for logging OBD1 LT1's
TunerPro works okay too though. I never could get the trace feature to work to make adjustments to various tables but it's also been a while since I messed with TunerPro.
Old 04-01-2012, 08:42 AM
Is it just the EFILive v4 scan tool that you're using?
Old 04-09-2012, 10:48 PM
LSxPwrDZ's Avatar
Yes works pretty good but tuner pro is nice with the cell trace features.
Quick Reply: tunerpro rt and data logging 95 lt1
