2.5 bar os for ls1 ecm
Old 03-30-2012, 03:56 PM
TermnEatr's Avatar
Default 2.5 bar os for ls1 ecm
I cant find any 2.5 os is there one im missing? The only one i find is HP tuners for the e40 ecm. Btw this is on a 2000 camaro ecm thanks
Old 03-30-2012, 04:04 PM
7 Second Club
NicD's Avatar
LS1s can have either a 2 or 3 bar setup so take your pick.
Old 03-30-2012, 06:04 PM
LSxPwrDZ's Avatar
It's best to use the 3bar OS and then input whichever sensor data you have into the map sensor calibration.
Old 03-30-2012, 07:24 PM
TermnEatr's Avatar
Is there a direct fit 3 bar to ls6 intake that will work with the Ls1 ecm
Old 03-31-2012, 12:22 AM
gectek's Avatar
The 2.5 bar from the cobalt should work.....used to be from a 3800 supercharged car. Close enough right?
Old 03-31-2012, 02:42 PM
TermnEatr's Avatar
I'm trying to get a mail order tune but the guy said there's only 2 or3 bar OS no 2.5 exist for Ls1 fbody
Old 03-31-2012, 05:04 PM
LS1TECH Sponsor
foff667's Avatar
Correct, only 2 or 3 bar.
Old 04-05-2012, 08:13 PM
LSxPwrDZ's Avatar
The 2 or 3bar OS is not limiting you to those particular map sensor's though, that just defines the capabilities of the VE table within the OS. You can install a 3bar OS and use a stock map sensor if you wanted to but it would only read up to the 105kpa load point. Basically put the 3bar OS in it and then use whichever sensor you want to use and input the map sensor calibration and you'll be set. Some people like the motorola 2.5bar sensor, it can be used but will only read up to ~250kpa using the correct sensor calibration under Eng Diag. tab.
Old 04-06-2012, 08:18 AM
TermnEatr's Avatar
I have the dpe corvettes 2.5 map thanks for the info!
Quick Reply: 2.5 bar os for ls1 ecm
