Can i start my new engine without a tune? - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 04-20-2012, 07:51 PM   #1
Default Can i start my new engine without a tune?
Going to be putting in a lq4 390ci engine into my 2000 Camaro SS. In putting in a cam and headers and ory. My question is... Can I start it and make sure that it runs properly before I take it to get it tuned? It would suck to set up an appointment get there and it not start or blow up for some odd reason. So can I just start it to make sure everything is ok without a tune?
703 CAMAROSS is offline   Reply With Quote
Old 04-21-2012, 06:10 AM   #2
In my opinion, if you're running stock injectors and you've got a decent size cam, it may start and idle with a little pedaling. If you've got bigger injectors, don't run it very long. Best bet is to ask your tuner after providing him with all the details though.
SMOKINV8 is offline   Reply With Quote
Old 04-21-2012, 07:01 AM   #3
I have a feeling any tuner will say no just so they can get me for a start up tune so I figured I would ask people on here.
Old 04-21-2012, 12:19 PM   #4
SladeX's Avatar
As long as the cam isn't too radical and you've hadn't changed injectors, the car should start with maybe some throttle being required to keep it alive. Once it kicks into closed loop, it should "run" but you should be careful and just baby it.
SladeX is offline   Reply With Quote
Old 04-21-2012, 12:32 PM   #5
Yeah I don't even want to drive it without a tune I just want to make sure it runs ok.
Old 04-21-2012, 08:15 PM   #6
BLK02WS6's Avatar
You haven't said anything about the injectors - if you have bigger injectors then don't even start it without a base tune! It will be very rich and you could wash the rings very quickly... If it has injectors that match the tune in the car, you are fine to run it...
BLK02WS6 is offline   Reply With Quote
Old 04-21-2012, 10:46 PM   #7
Yes the injectors are stock ones. The tune is also. It's going to be a major change. All I have done to it is a catback and now I'm doing all this at 1 time. Can't wait!
Related Topics
Thread Thread Starter Forum Replies Last Post
no start after reflash hp tuners autoaddictions PCM Diagnostics & Tuning 3 03-18-2016 06:57 PM
Starting Engine Without Water Pump Snorkelface LT1-LT4 Modifications 3 12-24-2015 06:01 PM
My adventure in to tuning! Tips and tricks before you try it yourself. Nicelysedate PCM Diagnostics & Tuning 11 11-10-2015 03:51 PM
cheapest 5.3 turbo setup possible Black01M6SS Forced Induction 38 01-31-2015 06:28 PM
First start up no pcm flash Dburch89 Conversions & Hybrids 8 09-21-2013 08:14 AM
Tags
bigger, car, drive, engine, injectors, lq4, ls, motor, put, started, swap, tune, tuned, tuner, turbo, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
