EFI Live - Abuse Management Table?
Old 04-24-2012, 05:34 PM
Bill00Formula's Avatar
Default EFI Live - Abuse Management Table?
Just saw this table for the first time.
Says upper level - 6,600 rpm
Lower level - 6,500 rpm
Abuse mangement commanded fuel .833
Does anyone know anything about this. Is this ok to leave it where it is?
Thanks
Old 04-24-2012, 06:45 PM
joecar's Avatar
Hi Bill, what year/vehicle/ECM...?
Old 04-24-2012, 09:40 PM
2000 formula, 6 spd
Old 04-25-2012, 10:37 AM
joecar's Avatar
Are you referring to the Abuse tables in the transmisson segment...?
Old 04-25-2012, 10:56 AM
Higgs Boson's Avatar
Just set abuse tables to a setting that can't be engaged, like enabled over 7500 or something.
Old 04-25-2012, 07:03 PM
Thanks, It's a folder under engine calibration called abuse management.
Old 04-27-2012, 07:38 AM
kenp's Avatar
It comes oem so that abuse management can only be activated if throttle position is greater than 100%. I don't change anything in that table. Never been a factor or issue.
Old 04-27-2012, 09:37 AM
Not all cars/trucks are the same calibration from the factory.
Old 04-30-2012, 06:41 AM
kenp's Avatar
Yes, that's correct. The LS oem parameters that I've seen, including a 2000 Formy have B1207 set to "0" and so abuse management is disabled unless you're sitting still. Out of curiousity, which ones come oem with Abuse management enabled above zero kph/mph?
Quick Reply: EFI Live - Abuse Management Table?
