Can anyone review this HPT scan?
Old 05-04-2012, 09:01 AM
udienow's Avatar
Default Can anyone review this HPT scan?
The problem the car is having can be found in this thread:
https://ls1tech.com/forums/generatio...e-install.html
Its a 00 camaro and the intake was just swapped to ls6. Car had no issues prior to swap.
Is there anything on the scan that could point me in a direction of what is causing the problem? Problem is still there and its been a few weeks now.
TIA
File Type: hpl
Old 05-05-2012, 12:30 PM
ATEURZO6's Avatar
cant look at the log at work but sounds like the Air flow tables need to be tweeked ... maybe a touch taken out .
But like i said cant look at the file at work . I will tonight when i get home . And if you di make adjustments of course make all other adjustments as needed with that also... VE ect ect
Old 05-05-2012, 12:55 PM
CLRD4TO's Avatar
Besides of course tuning the VE table and MAF tables separately for the intake install, looks like you need to touch up idle tuning.
Go to the hptuners forum and search for RussK idle airflow config file and scan the car with that. Likely your idle trims are causing the revving. Been there...idle tuning is frustrating. Use the histogram to plot idle airflow and tweak the tune with that. Mine wasnt as easy as copy/paste but close enough.
Old 05-05-2012, 07:22 PM
ATEURZO6's Avatar
hey just looked at the log , do you mind posting the tune or even email it to me carlspencesfe@gmail.com
Old 05-06-2012, 06:19 AM
Brad Campbell's Avatar
Can you post the tune up? Unless I'm missing something in the log it may be helpful to add things like desired idle rpm's, airflow and trims for the idle PID.
Old 05-07-2012, 01:23 PM
udienow's Avatar
Sorry I don't know much about this stuff.. what do you mean to post the tune? This car was never tuned if that is what you are referring to...
Old 05-07-2012, 01:26 PM
You are logging the car with hptuners right?
Old 05-07-2012, 01:43 PM
udienow's Avatar
Yes my friend has it... we hooked up this car and just drove around and the file he sent is what I got. I dont actually know anything about this stuff myself.
Old 05-07-2012, 01:49 PM
Is your friend handy with hptuners? Is he willing to sell you the credits to tune your car?
Old 05-07-2012, 02:01 PM
udienow's Avatar
This car is already unlocked with his HPTuners... I dont think my friend really knows much i mean he didnt do anything when we scanned it... thats y i posted it up.
Old 05-07-2012, 02:11 PM
OK. Great! I think you could add some parameters to your log that will help to show exactly what your car is doing. It will also help people here to make suggestions towards improvement. I don't have access to my logging computer right now, but I can send a configuration over later that may help out.
Old 05-07-2012, 02:23 PM
udienow's Avatar
Awesome, sounds good.. thanks!
