speed density tune
Old 05-14-2012, 08:51 PM
paul1379's Avatar
Default speed density tune
speed density tune pros and cons??? im going through speedinc im upgrading to larger headers, larger air lid, remove MAF, cutouts.. im running a LS3 416 with trickflow 235 heads, port 92 fast intake. they promise me around 30 rwhp more... any truth to this?
Old 05-14-2012, 10:01 PM
stangtrader's Avatar
Idk if theres truth to that but I can say I am far happier running a sd tune vs a maf tune. Car has great driveability. Better than it was with a maf. It may very well be possible to gain 30 hp if your maf is pegged
Old 05-15-2012, 12:06 AM
minytrker's Avatar
A SD tune will only make more hp IF your MAF was a restriction and you remove and replace it with a larger diameter pipe. Just doing a SD will not make anymore hp.
Old 05-15-2012, 07:43 AM
NoGo's Avatar
You'll pick up HP with all the other mods, but little if any of it will be from switching to the SD tune.
You may get better throttle response and drivability with the SD tune if they do a reasonable job.
Old 05-15-2012, 04:07 PM
minytrker's Avatar
If a tune is done right you can not tell any difference between SD or a normal tune.
Old 05-15-2012, 04:49 PM
Higgs Boson's Avatar
*qft*
Old 05-15-2012, 05:33 PM
scooter k's Avatar
http://www.pcmforless.com/index.php?...ning&Itemid=56
Old 05-15-2012, 08:35 PM
^great info for and well drawn out and easy to understand
Quick Reply: speed density tune
