cylinder #8 misfire
cylinder #8 misfire
i am having a issue with a soft code on #8 cylinder and it is only missing at very high rpms. this is what i have done so far
changed all plugs
fixed various vacume leaks
my mods are somewhat aggresive cam, ported 243s boltons yada yada. i also installed a fast90/90 a while back. now the car ran fine after my head and cam install for months. so anyway, i installed the fast 90 and the car ran fine for a month or so, then all of a sudden BAM! car starts running like **** as described above. car is much better now that the leaks are fixed and the plugs are replaced i even did 3 wot pulls and no cutting out occured. the car is back to misfiring and i need to know why. my guess is fuel pump maybe since it is stock peice and i have heads and cam. do you guys think its fuel pump or maybe the inatke has somethin to do with it or maybe somethin else?
changed all plugs
its not the fuel pump or it would be on more cylinders than #8.
did you do plug wires?
if you did not.
the cheapest way would be to swap out #8 plug wires with a diffrent cylinder and see if it follows or stays on that cylinder it will tell if the wire is shoot. if that dont fix it i would swap #8 injectors and see if that fixes that cylinder. if not then do the #8 coil with a diffrent cylinder coil and see if it follows or stays on the same cylinder. then after that it is for sure in the cylinder/head if none of them fixed it. i would do a compreesion and leak down after that.
and coils usually only screw up when warm compaired to cold but they still do screw up when cold
if you did not.
if you did not.
if you did not.
i would guess plug wire. if its not fuel and you have new plugs. what plugs did you use? i put autolites in my tahoe and got knock codes like crazy. went to a ngk 5 like i should have because thats what i always run and the problem never came back
i switched a coil and took it out for another test and guess what? it ran fine again, i even treid beating the **** out of it just to make the code come up and could not do it. but thats only cuz i had the scanner with me lol. next time without the scanner it will run like poo guarenteed
