Popping and farting then smooth
Old 06-04-2012, 01:59 PM
RPD_Vette84's Avatar
Default Popping and farting then smooth
slowly learning HPTuners and everyone has been a great help but need a bit more help. ive been tryin to tune it and its running alright but have some issues. while cruisin around it pops and farts until i get into boost then it runs smooth but its really rich. its a 2bar SD tune with no o2's.
i will try and get a log as soon as im able to.
info on the car:
4.8l
t56
edelbrock vic jr intake with low pro elbow
FAST 90mm tb
60lb injectors
NGK TR8's
2 bar map
t76 turbo 8lbs of boost
no o2's only AEM wideband.
ecu is a stock 2001 4.8l
any help is greatly appreciated and thanx in advance
File Type: hpt
Old 06-04-2012, 03:03 PM
salemetro's Avatar
As far as I can tell, timing looks REALLY conservative below 1600. Anyone else have any thoughts?
What base tune file did you start with?
Old 06-04-2012, 05:03 PM
i believe i started with a stock 4.8l tune and then followed HPTuners videos to convert it to an SD tune. since then i havent really messed with it axcept for turning off some of the check engine lights. i dont have my wideband hooked up to the HPTuners but i can log a little bit of it running and driving up the street.
Old 06-04-2012, 05:12 PM
salemetro's Avatar
Yeah....get the W/B hooked up and logging....then post a log file here. I'm sure that you'll get MUCH more useful replies from others once they are able to see a good log file.
Old 06-04-2012, 05:16 PM
alright ill try and do that today. thanx
Old 06-04-2012, 06:37 PM
also need some help bringing the idle down. its stuck at like 1200-1500
Old 06-05-2012, 12:45 AM
MikeyZ's Avatar
have you check for vacuum leaks? thats the number one symptom
Old 06-05-2012, 01:02 AM
salemetro's Avatar
There's A LOT more not right in his tune....it's currently too much for me to sort out (I'm still learning too)...but there appears to be incorrect TQ control settings, pe adder settings, ect. I'm kinda curious as to why no O2s? The tune does not appear (at least to my eyes) to be set up correctly for OLSD.
Also curious how he's been "tuning" much of anything at all without a w/b logging?
Looking forward to seeing a log file.
Old 06-05-2012, 01:20 AM
Yeah like i said i dunno what was on the ecu. It was supposed to be a stock 4.8l 6spd tune and then i followed whatever steps HPTuners video showed for converting it to SD. Then i just went thbrough and turned off some of the check engine lights. I have a wideband hooked up but just not hooked up to hptuners yet. I gotta look up where the 2 wires go on the HPTuners again so i can hook it up.
I am a newb to tuning and this is why im asking for help.
Old 06-05-2012, 05:05 PM
alright so i got to do a little test pass up the street. hopefully you can view this. realize my VSS signal is a bit off. lol
the car pulls but does not feel like i think it should.
File Type: hpl
