can knock sensors be tuned out?
Old 06-10-2012, 10:07 PM
Leeroyws6's Avatar
Default can knock sensors be tuned out?
i was installing a knock sensor today and i broke the stem that it bolts into.i no longer have a place to mount the rear knock sensor.one of my options is to mount it to the side of the block.there are supposedly more holes where i would be able to mount it.now i was wondering if there is a way to delete the knock sensor totally?like in a tune?
Old 06-10-2012, 10:16 PM
LS1Tech Sponsor
Slowhawk's Avatar
Yes, you can delete them. I shut them off in all my personal cars. But, I'm also the one tuning them. The tune has to be good.
Old 06-10-2012, 10:23 PM
Leeroyws6's Avatar
ok thanks.i will definately look into that.i just dont want the ses light to come on.and i dont want my ignition timing being retarded or anything.gonna try to mount it to the side of the block.then im calling my tuner in arlington texas and see what he recommends.
Old 06-11-2012, 01:22 AM
got-a-ls1's Avatar
slowhawk curious as to why you delete them? do you find you get a lot of false knock? ive often wondered how accurate the knock sensors are when you doubling and tripling the stock power levels... just asking because i have considered it before
Old 06-11-2012, 11:14 AM
flattusmaximus78's Avatar
Do most tuners do anything with them during tuning on a car with a big cam and exhaust ao that they don't detect false knock an pull timing?
Old 06-11-2012, 06:38 PM
LS1Tech Sponsor
Slowhawk's Avatar
False knock problems when racing. My 02 Vette running 14lbs on the stock motor would false kr all the time. Unplugged them and drove it 3 years on the stock motor with no problems.
Old 06-11-2012, 07:00 PM
edcmat-l1's Avatar
Cuz he haz big ballz LOL
Old 06-11-2012, 07:01 PM
edcmat-l1's Avatar
See, now that takes big ballz LOL
Old 06-12-2012, 02:20 PM
white01ss's Avatar
I've had success turning down sensitivity and turning up recovery rate so I guess my ***** are not so big. During a dyno session kept getting false knock from some weird harmonics with the above ground DynoJet dyno so had to turn them off.
Old 04-06-2013, 06:33 PM
keithbessler's Avatar
Are there aNy benefits to tuning them out? Doing a turbo build and am tearing down my engine to clean it and was wondering if it'd just be better to buy a new valley cover with out the knock sensor holes
Old 04-08-2013, 01:02 PM
white01ss's Avatar
Only benefit is to prevent false knock. If your setup produces false knock then you will need to turn it off. If it doesn't then I'd leave it on to protect against bad gas. It comes down to how comfortable you are not having them.
For 80 years there was no such thing as a knock retard, cars had to be tuned for the worst fuel and conditions from the factory. Nowadays, cars are turned for economy and have to eek out all the hp they can.
Quick Reply: can knock sensors be tuned out?
