2001 computer in a 99 car. Having problems with the voltage
Old 06-17-2012, 08:10 AM
dnkynrbk's Avatar
Default 2001 computer in a 99 car. Having problems with the voltage
Ok see if someone can help me. Built a 99 camaro I used a 2001 computer and harness in the car. The problem Im having is its losing voltage.
its starts at only 12 volts I drove the car 20mils the voltage droped to 9volts and stayed there and drove fine but had slow turn signals that stayed on.
I put a new battery and 2 new altanators and a new excitor wire plug. so and it did the same thing. So basically its not charging the battery
on hp tuners it doesnt show up any codes.
the 2001 wiring harness I bougt has the one wire and then had 2 other wires connected to it but had caps on them.
question does the 01 just use one wire and which color of wire should it be coming off the harness.
thanks for any help
Old 06-18-2012, 05:01 AM
dnkynrbk's Avatar
Anyone have this issue
Old 06-18-2012, 05:39 AM
TXSZ66AVLANCHE's Avatar
I have this issue, mine will only charge if the headlights are on. Swapped alternator and still same.
Old 06-18-2012, 08:00 AM
ramairetransam's Avatar
hows your connection at the battery , do a voltage test to see what the alt is giving off .
Old 06-18-2012, 12:11 PM
Moderator
jimmyblue's Avatar
Could be something about the exciter wire. Check that
there's no harness difference (suspect not, but maybe
a pushed-out pin or something, even a bad PCM exciter
output?).
Old 06-19-2012, 09:04 AM
dnkynrbk's Avatar
Ill check it there is 3 wires in that area where the exciter wire is whoever had the harness before me has a connector on there. What color of wire is the excutir wire
Old 06-19-2012, 09:07 AM
dnkynrbk's Avatar
So I'm just using the one wire the other two are just capped off. Ill check the battery voltage again
Old 06-21-2012, 10:08 AM
dnkynrbk's Avatar
Bump any other idea
Old 06-22-2012, 11:19 AM
dnkynrbk's Avatar
Ill post a pic up Sunday of the 3 wires coming off the harness
Old 06-24-2012, 09:13 PM
dnkynrbk's Avatar
Any other ideas anyone
