LQ4 harness mod problem HELP!!!
Ok i finished redoing my harness using the info on lt1swap.com and everything came out great except i took out the engine coolant temp sensor signal out. Now im breaking my head trying to figure out how to put it back. The sensor has 2 wires 1 yellow and one gray i put the yellow one back to its pin but where does the grey one go too? Im freaking any help on this
So what Sensors are all needed for making a standalone harness? I just want to make sure im not missing anything double checking. And who can i send my pcm for reprogramming for vats etc.? Thanks for all the help
Cool well i did exactly whay was on lt1swap.com pretty easy with all the info there i cancelled alot of sensors including the trans wires i will using my 4spd muncie. Who can i send my pcm for programing?
