Dead at the key
Dead at the key
I have a 94 Formula. I've had very little issues with thus car. So of course yesterday started great the first half. the after washing it. (Outside only) I went to leave and wouldn't turn over. everything else came on like it should. Figured ok starter. Well it did in fact go bad. I even jumped across the solinoid to see if I got a bunk one. So today I swapped the ignition switch. Still nothing. I checked wires, fuses, connections, etc. I even tried a different key. Can anyone help?!
Posted from LS1Tech.com App for Android
if it's manual i'd check the clutch pedal sensor (or whatever it's called). If auto check the brake sensor. They're under the dash (durr). I had the same issue with mine. Just cleaned the contacts and it was good to go
There's a LS1tech app now?? huh
