Tune Going Lean - Out of The Blue???
'02 Camaro, specs in my sig. I did my own tune a couple years a go with EFI Live and I was pretty happy with the results. I have an LC1 wideband with a display so I can see A/F ratio. It didn't always lock in at 14.6 but would maybe vary a few tenths up / down, no biggie. But out of the blue last week it started going real lean on cruise, idle, everything, and it jumps all over the place - maybe 14.0 all the way to 17 - averaging 15.5 or so. I re-calibrated the LC1, still the same on the display and verified by EFI Live. I don't get a check engine light and I can't find a vacuum leak. LTFTs are +10% or so which verifies the lean condition. WOT seems good and the A/F goes to 12.2. and stays there. Can you guys suggest some things to check? Do I have a bad O2 sensor? Thanks in advance.
