Dtc p0118
Old 08-08-2012, 01:48 PM
peterock98's Avatar
Default Dtc p0118
When there is heavy rain my car through this code p0118 .Pcm or wiring issue?
Old 08-08-2012, 02:26 PM
62n62's Avatar
Default p0118
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
Circuit Description
The Engine Coolant Temperature (ECT) sensor contains a semiconductor device which changes the resistance based on the temperature (a thermistor). The ECT sensor is mounted in the left bank cylinder head near the front of the engine. The ECT sensor has a signal circuit and a ground circuit. The PCM applies a voltage (about 5.0 volts) on the signal circuit to the sensor. The PCM monitors the changes in this voltage caused by changes in the resistance of the sensor in order to determine the coolant temperature.
When the coolant is cold, the sensor (thermistor) resistance is high. The PCMs signal voltage is only pulled down a small amount through the sensor to a ground; therefore, the PCM senses a high signal voltage (low temperature). When the coolant is warm, the sensor resistance is low. The signal voltage is pulled down a greater amount; therefore, the PCM senses a low signal voltage (high temperature). At normal operating temperature, the voltage should measure about 1.5–2.0 volts at the PCM.
When the PCM senses a signal voltage higher than the normal operating range of the sensor, this DTC sets.
Conditions for Running the DTC
The engine run time is greater 60 seconds.
Conditions for Setting the DTC
• The Engine Coolant Temperature is less than –39°C (–38°F).
• All conditions met for 20 seconds.
Action Taken When the DTC Sets
• The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important:
• Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM.
• For any test that requires probing the PCM or component harness connectors, use the Connector Test Adapter Kit J 35616 . Using this kit prevents any damage to the harness connector terminals.
• The following may cause an intermittent:
- Poor Connections
- Mis-routed harness
- Rubbed through wire insulation
- Broken wire inside the insulation
• If the engine has sat overnight, the engine coolant temperature and intake air temperature values should display within a few degrees of each other. If the temperatures are not within 3°C (5°F), refer to Temperature vs Resistance.
• If you determine that the DTC occurs intermittently, performing the P1115 diagnostic table may isolate the cause of the fault.
• For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2 This step determines if the malfunction is present. For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616 . Using this kit prevents damage to the harness connector terminals.
3 Using the Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This will isolate when the DTC failed.
4 An engine coolant temperature above 139°C (282°F) indicates the PCM and ECT sensor wiring is OK.
5 An engine coolant temperature above 139°C (282°F) indicates the PCM and ECT sensor signal circuit is OK.
6 Disconnecting the PCM allows using the DMM J 39200 in order to test continuity of the circuits. This aids in locating an open or a shorted circuit.
8 Disconnecting the PCM allows using the DMM J 39200 in order to test continuity of the circuits. This aids in locating an open or a shorted circuit.
11 Inspect for proper terminal tension/connections at the PCM harness before replacing the PCM.
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
1. Install a scan tool.
2. Turn ON the ignition leaving the engine OFF.
3. Monitor the ECT sensor display on the Engine 1 Data List of the scan tool.
Is the ECT sensor at the specified value?
–39°C (–38°F)
Go to Step 4
Go to Step 3
3
1. Turn ON the ignition leaving the engine OFF.
2. Review the Freeze Frame and/or Failure Records data for this DTC and observe the parameters.
3. Turn OFF the ignition for 15 seconds.
4. Start the engine.
5. Operate the vehicle within the conditions required for this diagnostic to run, and as close to the conditions recorded in the Freeze Frame/Failure Records as possible. Special operating conditions that you need to meet before the PCM will run this diagnostic, where applicable, are listed in Conditions for Running the DTC.
6. Select the Diagnostic Trouble Code (DTC) option, the Specific DTC option, then enter the DTC number using the scan tool.
Does the scan tool indicate that this diagnostic failed this ignition?
Go to Step 4
Go to Diagnostic Aids
4
1. Disconnect the ECT sensor electrical connector.
2. Jumper the ECT sensor harness terminals together.
3. Observe the engine coolant temperature parameter on the scan tool.
140°C (284°F)
Go to Step 9
Go to Step 5
5
Jumper the ECT sensor signal circuit to a known good ground.
140°C (284°F)
Go to Step 8
Go to Step 6
6
1. Turn OFF the ignition.
2. Disconnect the PCM connector C2 located on the same side as the manufacturer's logo. Refer to Powertrain Control Module Replacement/Programming .
3. Test the ECT sensor signal circuit for an open.
Is the ECT sensor signal circuit open?
Go to Step 7
Go to Step 11
7
Repair the ECT sensor signal circuit. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 14
8
3. Test the ECT sensor ground circuit for an open.
Is the ECT sensor ground circuit open?
Go to Step 10
Go to Step 11
9
Replace the ECT sensor. Refer to Engine Coolant Temperature Sensor Replacement .
Go to Step 14
10
Repair the ECT sensor ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 14
11
1. Test for a short to voltage on the signal circuit.
2. If you find the signal circuit shorted to a voltage repair the condition as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 12
12
1. Inspect for faulty connections at the PCM. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
2. If you find a poor connection repair the condition as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 14
Go to Step 13
13
Important:: Program the replacement PCM. Refer to Powertrain Control Module Replacement/Programming .
Replace the PCM.
Go to Step 14
14
1. Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
2. Idle the engine at the normal operating temperature.
3. Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
Go to Step 15
Go to Step 2
15
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to the applicable DTC table
System OK
Old 08-08-2012, 03:50 PM
peterock98's Avatar
Thanks.
Quick Reply: Dtc p0118
