E85 Help
E85 Help
I am having mixed ideas about how to start off an E85 tune. I have succesfully ran E85 before on a vehicle with taking 30% out of injector flow rate vs KPA and leaving stoich at 14.7 for everything.
I am targeting 12-12.3 afr for PE on the gas scale which is about .81-.83 lambda
was wondering if someone can critique my setup and let me know about how you sucessfully ran E85 if possible.
Thanks in advanced!
Info about my setup:
rebuilt forged 347 LS1 with PRC stg 2.5 heads (62cc), 268/270 at .050" .657" lift, 108LSA, Fast 102 manifold and TB, 60lb motoron inj.
Running a Haltech 103R using a LS7 style MAF.
In a 2002 camaro M6
Thanks in advanced!
In a 2002 camaro M6
recommend not doing what you plan on doing.
change your stoich and modify your ve. e85 uses about 30% MORE fuel, not less.
I copied this from another forum, the "red" I left out so the values listed are usable:
stay out of the RED.
Lambda E85 AFR Gas AFR
0.700 6.832 10.290
0.710 6.930 10.437
0.720 7.027 10.584
0.730 7.125 10.731 @ Max Power Multi Turbo
0.740 7.222 10.878
0.750 7.320 11.025 @ Supercharged/Turbo
0.760 7.418 11.172
0.770 7.515 11.319 @ Max Power NA
0.780 7.613 11.466
0.790 7.710 11.613
0.800 7.808 11.760 @ Consistant Race
0.810 7.906 11.907
0.820 8.003 12.054
0.830 8.101 12.201
0.840 8.198 12.348 @ Part throttle RACE
0.850 8.296 12.495
0.860 8.394 12.642
0.870 8.491 12.789 @ Idle
0.880 8.589 12.936
0.890 8.686 13.083
0.900 8.784 13.230
0.910 8.882 13.377 @ Part throttle STREET (economy)
0.920 8.979 13.524
0.930 9.077 13.671
0.700 6.832 10.290
0.710 6.930 10.437
0.720 7.027 10.584
0.740 7.222 10.878
0.760 7.418 11.172
0.780 7.613 11.466
0.790 7.710 11.613
0.810 7.906 11.907
0.820 8.003 12.054
0.830 8.101 12.201
0.850 8.296 12.495
0.860 8.394 12.642
0.880 8.589 12.936
0.890 8.686 13.083
0.900 8.784 13.230
0.920 8.979 13.524
0.930 9.077 13.671
By reducing his IFR by 30% he is adding 30% more fuel... (can you see why...?)
But he could simply do this: leave the IFR alone, set stoich to 9.76, and then adjust PE as necessary to achieve 0.81-0.83 lambda.
I didnt think it was that simple by just changing stoich and PE. Suppose its worth a try. I have the car idleing but it wont rev up or drive to well...
Thanks for all the Values 98Camarod
Moderator
I tried shortcutting it and not changing the Stoich table by adjusting VE since I am 1 bar SD. I could not get it to idle for my life, but part throttle and WOT were fine.
I then went to a basic stock tune with my 1 bar SD, changed Stoich and PE, redid the VE table before going WOT.. Man, what a difference. Runs like a champ!!
I can run 91, E48, and E85 with just a simple Stoich/PE change (and timing for 91, 13-1cr/8.7dcr).
