ls3 slow return to idle
Old 08-30-2012, 10:13 PM
carguysnet's Avatar
Default ls3 slow return to idle
Thanks in advance for any help.I just installed a ls3 376-525hp. GMPP crate engine with a Tremec magnum 6 speed.The wiring harness and matched controller are also GMPP.Has a steady idle and revs fine.Problem seems to be it is slow to return to idle.Not drastic but noticeable especially between shifting gears.If you shift at 2000 rpms there is no drop in RPM's between the gear change.Just doesn't feel right.Also slow to return when parked.Any advice appreciated.
Old 08-30-2012, 10:47 PM
Vexzer's Avatar
Warranty & tech support from GMMP? You musta spent a tidy sum on that stuff -sounds like an awesome build!
Old 08-31-2012, 12:26 AM
Avanti's Avatar
Did it come with a manual with a coupon for a free GM idle-check after installation, like my LS3 E-Rod engine? Just curious. Sounds like what it might need.
Old 08-31-2012, 12:31 AM
Gavin Johnson's Avatar
Usually that's a sign of a vaccum leak
Old 08-31-2012, 12:43 PM
carguysnet's Avatar
Default slow to return idle
Just spoke with GM Performance.Extremely helpful and sharp.This is the way the ECM is programmed.Slow back to idle.They had complaints about stalling when coming to a stop.Said it may get better with use but will always be there.I asked about changing this function but he said no.
I would like the revs to drop quicker.Does any one have any experience in changing this function?
Old 08-31-2012, 01:25 PM
Jon5212's Avatar
^^^ Just get it EFI live or HP tuned by someone?
Old 09-01-2012, 03:24 PM
Vexzer's Avatar
lightweight flywheel!
Quick Reply: ls3 slow return to idle
