SD Tune, should I remove MAF wires?
I am in the process of going through my wire harness for my LQ4 turbo build. If I am going to have a SD tune on HP Tuners, should I just remove my MAF wires and plug from the PCM now? Or is there a reason to have the wiring?
Thanks
Thanks
pretty sure you should never divulge your "new here" status on this forum...peoples lips slam shut and become not so helpful...I am new to this f-body/ls motor stuff too....and I'll be damned if I can get someone to be friendly enough to actually help me out...I am supposed to "search"....
To the OP...If you NEVER intend to go back to a MAF setup, then go ahead and delete them....as long as you have an IAT installed elsewhere in the system.
Possibly. The only one that I've seen though, is an adapter to combine the 3-wire maf leads and the old-style IAT leads to the newer 5-lead maf plug....to to use the newer maf. If the OP is certain that he'll never go back to a maf-based tune, I'd just delete the 3 wires for the maf and re-route the 2 for the IAT sensor to desired location.
That's a pretty rough assessment. Generally, we all try to be as helpful as possible. As with any forum, there's a douchebag in EVERY crowd....but very few here (in my experience). With that in mind....there are MANY times that questions can easily be answered through the search function.....especially questions that have been answered a billion times before. Depending on what you're asking, it might have been answered many many times before.
sorry to hijack the thread...just venting and feeling sorry for other guys asking questions and getting no where....
In your long history and 14 posts you have answered the long pondered question is tech helpful?
OP. You can cut them out but I like to leave the engine harness uncut if for any reason in the future you want to do a swap or part it out. Swap to a M6 etc. To me there isn't enough weight savings to do it.
Agreed.....sometimes, it's better to leave things as they are for future/unforseen changes. At the same time, if the OP is absolutely certain that he's not going back to MAF, it can help to make an engine bay look a little more clean.
understood...however not might experience so far. ofcourse there is probably a thread "somewhere" that might ambiguously answer your questions...but one might be left with some doubt...so, that being said, it seems to be a crime to ask for a direct answer to a certain question here in this forum. just sayin...
I know on my 96 conversion there was little help as far as fitment of parts for my setup. Sometimes it takes lots of patience and....wait for it....searching. It's just a fact of life.
Maybe this will help ya out.. http://store03.prostores.com/servlet...sh-wire/Detail
98-02 F cars do not need this.
I have a 99 truck harness.
From what I read on this subject, most cars that run forced induction right now run a SD tune.
I was only asking to remove the wires to clean up the engine bay. I suppose I could just shorten the wires and run them out of the way. Then just use an extension to the MAF if I ever need to run one.
Thanks for the reply's guys.
