Problems!! Please help. Car idles fine but when I put it in gear and accelerate dies
Heres the details. 2000 ls1 with Lg Motorsports cam and all the other supporting parts. The car will idle fine but it dies once in gear and I push the accelerator. I checked the iac out to see if It is functioning and it is. Possible PVC?? It does have a stock intake. I'm lost and need to figure out the problem ASAP. Thanks guys any suggestions will be huge help at this point.
need alot more info man. Did it run fine before then just start doing it? does it rev fine in p/n? give as much info as possible and i'm sure somebody will be able to help you out
It started doing it over a period of time aproximately 2 months I would have to feather it to reach an rpm and then it would run fine until a stop sign then repeat. It will not rev at all in park and nuetral let alone anything else. Thanks for the interest im looking everywhere for info to atleast get it moving until I can get it to a tuner
@outkast the check engine light is on for several reason. 9 codes mostly of what are expected but an iac I found abnormal. The iac is working when I turn the key I found out the hard way after I checked the codes and pulled the Iac turned the key and it went flying. Is it possible it's not working how it should be and causing this problem? Just trying to feel out all possibilities. Thanks for the input
was the car tuned after the th400 swap? as far as the iac with the key on it should fully extend itself, not sure about going flying though. do you have the ability to get a data log? if you do i'm sure somebody can help you out
