school me on 98 ls1 pcm's
Im building a 98 ls1 camaro and have heard the pcm's aren't so great. Is there any horsepower limitations with it? Is it able to get dyno tuned without any hand helds? Any info is greatly appreciated.
Just the PCM, you need to repin the harness using both wiring diagrams. Lot of info here.
98 PCM is capable of high horsepower engines, only if you plan to use high amounts of boost a 99+ PCM is best
Moderator
I plan to switch from a '98 to a '02 next month.
I purchased an empty set of connectors so that I can move the wires, one by one, from the '98 connectors to the new connectors. Nearly every wire needs to be repinned; removing all the wires and having 100+ loose wires would likely lead to a mixup.
