Z06 Maf freq, spark, PE, IFR, and VE tables wanted
I've got a 2000 fbody pcm, and Hptuners vcm edit that I'm using with a built ls6 motor. I'd like to import, or use as reference several tables from the Z06 pcm. If anyone has these, I would really appreciate taking a look. Thanks in advance
Moderator
I have an 01 Z06 table but that's all (for Z06)
in my collection. MAF changed for '02-up. I
think the place you're going to get the most
traction for this request is on HPTuners.com
and LS1Tuning.com (the latter being for Edit
and a much larger (currently) user base. Let
me know if this older MAF is the one you want
the table for. Conversely, if you do get one for
'02-up I would be pleased to add that to my
collection.
collection.
Originally Posted by FDLS6
Thanks guys.. Got it from the ls1howto site. Now if I can just round up some of the other tables. I'll try a post over at hptuners
I have just installed a LS6 Cam and ported LS6 heads into 2002 SS. I also have SLP headers and 36lbs injectors. I need LS6 data also, where did you find the data on ls1howto site. That is a great site, it helped me with my install.
Thanks
Bill
I uploaded my stock 2001 Z06 file to LS1Edit.com for you guys. There are several 2002 and 2003 files available also. Here's the link;
File Library Link
Good Luck!
joel
