Powertrain code?P0410 Secondary Air Injection System Malfunction
Old 10-08-2012, 02:31 PM
2002 T/A's Avatar
Default Powertrain code?P0410 Secondary Air Injection System Malfunction
Hey, I was wondering if anyone is familiar with this code "P0410 Secondary Air Injection System Malfunction". I am able to clear it but would like to know the possible cause? It only happens when I am cruising in 6th and approach a long uphill grade, RPMs are around 1500. It pulls OK, and I can down shift even though I don't need to, however, I would like to know what is going on with the emission system to cause it? Thanks, Les...
Old 10-08-2012, 03:43 PM
62n62's Avatar
DTC P0410
Circuit Description
A secondary air injection (AIR) pump is used on this vehicle in order to lower the tail pipe emissions during start-up. The powertrain control module (PCM) supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the heated oxygen sensor (HO2S) voltages in order to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages, and monitors the short-term fuel trim values for both banks of the engine. If the AIR system is operating correctly, the HO2S voltages should be low, and the short-term fuel trim should be high.
If the PCM determines that the HO2S voltages for both banks did not respond with the expected results during the tests, DTC P0410 sets. If only 1 sensor responded, the PCM sets either DTC P1415 or DTC P1416. The active DTC indicates which bank has the inoperative AIR system.
Conditions for Running the DTC
• DTCs P0101–P0103, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0171–P0175, P0200, P0300, P0335, P0336, P0351–P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, or P1441 are not set.
• The fuel level is more than 12.5 percent but less than 87.5 percent.
• The engine is running for more than 30 seconds.
• The maximum air flow is 22 g/s.
• The air fuel ratio is 13.125:1.
• The engine load is less than 40 percent.
• The ignition voltage is more than 11.7 volts.
• Vehicle speed is more than 15 km/h (25 mph).
• The engine is not operating in any of the following modes:
- Power enrichment
- Decel fuel cut-off mode
- The catalyst over temperature
• The engine is operating in a closed loop for more than 15 seconds.
• The engine speed is more than 850 RPM.
• The engine coolant temperature (ECT) is between than −10°C to +110°C (14°F–230°F).
• The intake air temperature (IAT) is between −10°C to +100°C (14°F–212°F).
• The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6.
Conditions for Setting the DTC
If the AIR pump turns ON during a closed loop operation and the HO2S voltage does not fall below 222 mV for 1.3 seconds.
Or
If the AIR pump turns ON during a closed loop operation and the short-term fuel trim does not change more than a predetermined amount.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important:
• Before you service the PCM or the throttle actuator control (TAC), remove any debris from the module connector surfaces, and from the module connector gaskets. Verify that the gaskets are correctly installed. The gaskets prevent debris from contaminating the modules.
• For any test that requires probing the PCM or probing a component harness connector, use the Connector Test Adapter Kit J 35616 . Using this kit prevents damage to the component terminals and to the harness. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Left Side of Vehicle
Ignition
B+
Right Side of Vehicle
Pump Supply
Control
• For an intermittent condition, refer to Intermittent Conditions .
• An intermittent may be caused by any of the following conditions:
- Low system air flow may cause this DTC to set.
- Excessive exhaust system back pressure
- Moisture, water or debris ingested into the AIR pump
- Pinched, kinked, heat damaged, or deteriorated hoses or vacuum lines
- Restrictions in the pump inlet, duct, or filter
• An AIR pump that has become inoperative and shows signs of exhaust gases in the outlet port would indicate a check valve failure.
• Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Testing for Intermittent Conditions and Poor Connections .
• If a repair is necessary, refer to Wiring Repairs or Connector Repairs .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3 If DTCs P0412 or P0418 are set, diagnose those DTCs first.
4 Inspects for excess resistance in all of the circuits that are associated with the AIR system.
5 This step tests for the battery voltage at the AIR pump relay.
6 This step tests for power to the AIR pump.
7 This step tests the ground circuit for the AIR pump.
12 This step tests for a grounded circuit between the AIR pump and the AIR pump relay.
22 A restriction in a hose or in a pipe, between the shut-off valve and the point where the system branches to each bank, causes the setting of this DTC . Inspect for kinks or for blockages from the AIR pump to the connection point where the AIR system divides.
Step
Action
Yes
No
Old 10-08-2012, 03:44 PM
62n62's Avatar
Default 410
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check–Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Is the AIR pump fuse OK?
Go to Step 3
Go to Step 11
3
Is DTC P0412 or P0418 active?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 4
4
1. Turn ON the ignition, with the engine OFF.
2. Command the AIR pump relay on with the scan tool.
Does the AIR pump turn ON?
Go to Step 8
Go to Step 5
5
1. Turn OFF the ignition.
2. Remove the AIR pump relay.
3. Test the B+ supply circuit of the AIR pump relay for an open using a test lamp connected to ground. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate?
Go to Step 6
Go to Step 16
6
1. Install the AIR pump relay.
2. Disconnect the AIR pump electrical connector. Refer to Secondary Air Injection Pump Replacement .
3. Connect a test lamp to battery ground.
4. Probe terminal A of the AIR pump electrical connector. Refer to Probing Electrical Connectors in Wiring Systems.
5. Turn ON the ignition, with the engine OFF.
6. Command the AIR system ON with a scan tool.
Go to Step 7
Go to Step 17
7
Test the ground circuit of the AIR pump for an open or poor ground connection using a test lamp connected to B+ and probing the B terminal of the AIR pump electrical.
Is the test lamp illuminated?
Go to Step 27
Go to Step 18
8
2. Disconnect the AIR pump outlet hose from the AIR pump.
3. Turn ON the ignition, with the engine OFF.
4. Command the AIR system ON with a scan tool.
Is air pressure present at the AIR pump outlet?
Go to Step 9
Go to Step 10
9
2. Disconnect the vacuum hose from the AIR shut off valve.
3. Start the engine.
4. Command the AIR solenoid ON with a scan tool.
Is a vacuum present at the AIR shut-off valve?
Go to Step 14
Go to Step 19
10
1. Inspect for a restriction or for a blockage in the AIR pump inlet hoses and in the AIR pump inlet pipes.
2. If you find a restriction or a blockage in the AIR hoses and in the pipes, repair the restriction as necessary.
Did you find and correct the condition?
Go to Step 29
Go to Step 28
11
3. Connect a test lamp to B+.
4. Test the B+ supply to the AIR pump and the AIR pump relay coil at the relay connector for a short to ground using a test lamp. Refer to Probing Electrical Connectors .
5. Refer to Diagnostic Aids for connector terminal identification.
Go to Step 23
Go to Step 12
12
1. Disconnect the AIR pump electrical connector.
2. Connect a test lamp to B+.
3. Test the AIR pump connector terminal A with a test lamp for a short to ground.
Go to Step 24
Go to Step 13
13
1. Install the AIR pump electrical connector.
2. Install a new AIR pump fuse.
3. Install the AIR pump relay.
4. Turn ON the ignition, with the engine OFF.
5. Command the AIR system ON with a scan tool.
Does the AIR pump fuse open?
Go to Step 28
Go to Diagnostic Aids
14
1. Install the following components:
• The AIR pump outlet hose to the AIR pump
• The vacuum hose to the AIR shut-off valve
2. Disconnect the outlet hose of the AIR shut-off valve.
3. Start and idle the engine.
4. Command the AIR system with a scan tool.
Is air pressure present at the outlet of the AIR shut-off valve?
Go to Step 22
Go to Step 15
15
Replace the AIR shut-off valve. Refer to Secondary Air Injection Shut Off Valve Replacement .
Did you complete the action?
Go to Step 29
16
Repair the open in the B+ supply circuit to the AIR pump relay connector. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
17
Repair the open in the AIR pump voltage supply circuit between the AIR pump relay and the AIR pump connector, or poor connections at the relay connector block. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
Go to Step 25
18
Repair the poor ground connection or the open ground circuit of the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 29
19
2. Disconnect the source vacuum hose from the AIR solenoid valve. Refer to Secondary Air Injection Solenoid Valve Replacement .
Is a vacuum present at the AIR solenoid valve?
Go to Step 20
Go to Step 21
20
2. Connect the source vacuum hose to the AIR solenoid valve.
3. Disconnect the vacuum hose to the AIR shut-off valve at the AIR solenoid valve.
4. Start and idle the engine.
5. Command the AIR solenoid valve ON with a scan tool.
Is a vacuum present at the AIR Solenoid Valve outlet?
Go to Step 21
Go to Step 26
21
Repair the restriction, the blockage, or the damage to the vacuum hose.
Go to Step 29
22
Repair the conditions in the AIR hose between the AIR shut-off valve and the point where the system branches to both sides of the engine.
Go to Step 29
23
Repair the short to ground in the ignition positive voltage circuit between the fuse and the relay. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
24
Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
25
Replace the AIR pump relay.
Did you complete the replacement?
Go to Step 29
26
Replace the AIR solenoid valve. Refer to Secondary Air Injection Solenoid Valve Replacement .
Go to Step 29
27
1. Inspect for poor connections at the AIR pump electrical connector. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
2. If you find a poor connection, repair the terminal as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 29
Go to Step 28
28
Replace the AIR pump. Refer to Secondary Air Injection Pump Replacement .
Go to Step 29
29
1. Clear the DTCs with a scan tool.
2. Turn OFF the ignition for 30 seconds.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run, and pass?
Go to Step 30
Go to Step 2
30
Use a scan tool in order to observe the stored information in Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
System OK
Old 10-08-2012, 10:25 PM
2002 T/A's Avatar
Holy ****, thats a lot of info, thanks. Les...
Quick Reply: Powertrain code?P0410 Secondary Air Injection System Malfunction
