Just got my hc ls1 tuned Code P0121
Old 10-15-2012, 09:21 PM
flattusmaximus78's Avatar
Default Just got my hc ls1 tuned Code P0121
5.3 heads, lunati nitrous cam, and a built motor. Street tuned with hp tuners.
Car is a 2002 a4 z28. Car runs awesome for the most part. The SES light comes up randomly.
Is this something to look into or is this a dumby code? Car runs great, my wide band is broken so I don't wanna go crazy if it would have any affect on my afr's or timing because the engine is new.
P0121
TPS/Pedal position sensor a ckt range/perf.
The above is the full code. Thanks guys!
Old 10-15-2012, 09:27 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've seen it a few times. Can be deleted if you first verify the tps is good.
Old 10-15-2012, 09:33 PM
Well that sounds good at least. I deleted the code for the mean time. I will check this weekend if it appears.
Old 10-17-2012, 05:41 PM
Code came on again today. I noticed it wanted to surge after wot with the code on. Car drives like stock otherwise so this surprised me.
Old 11-19-2012, 03:35 PM
Well the check engine light came on again. This time when it pops on the car gets really rich. 12.2 area on my wideband. If I turn the car off then back on it's fine. I also noticed my shift points are above 6500, now the car shifts at 5500 and the car never wants to downshift at all.
Old 01-02-2013, 12:34 PM
Okay changed the max and min tps settings in hp tuners and it solved the issue.
Quick Reply: Just got my hc ls1 tuned Code P0121
