PO300 code delet???
Old 04-10-2004, 11:42 AM
sting5841's Avatar
Default PO300 code delet???
I put a cam in and I know it's common to have the po300 code for random misfire but is there a way to get rid of it I have a predator right now so if you know any tricks let me know
Old 04-10-2004, 03:01 PM
sting5841's Avatar
come on guys anyone????????
Old 04-10-2004, 07:02 PM
blk~2000~Z28's Avatar
I am pretty sure you either change the RPM where it starts registering missfires to a higher level or you can delete it. I think you will need LS1-edit though for either method.
Old 04-10-2004, 07:13 PM
felton316's Avatar
Not sure with the Predator, but you can change the Low RPM misfire detection with LS1-edit to 32000 microseconds.
Old 04-10-2004, 07:16 PM
oOoLy's Avatar
If i have the LS1-edit hoe can i fix it ?
Old 04-10-2004, 07:41 PM
screamn03's Avatar
What I find funny is that the stock "microsecond" in the table is 32767 so how does changing it to 32000 help. I did this when I first got hp tuners and have still set the light. Wouldn't you want to increase that number to make it less sensitive. Someone chime in here because I don't really know what these values stand for, I just know that I tried it and it didn't work for me.
