Auto tune with manual trans. What to delete
I have a 2004 lq4 mated to a T56 in a 1971 El Camino. The PCM that I have is set up for an automatic transmission. I contacted HPTuners and they said that they weren't able to do a segment swap. So short of loading a new tune and paying to licenses it, is there any other way to get a manual tune. If not is there anything else that I need to do to my current tune to make it run right with a manual. I disabled all the DTC's for the tranny but wants sure if I got everything.
Disable all DTC's, hook the Vss and adjust it under speedo calibration and you will be fine. As long as the PCM sees vehicle speed you won't have any issues.
Even with no Vss it can work good, I have tuned several cars with automatic OS and no Vss for TH350/400 and no problems
It is still an auto file. I just clicked the manual option in the drop down list under trans type. It still has all the auto stuff in the file I just tried to disable a everything that looked to me like it was related to the auto tune. I Have compared it to a corvette file with a manual and the trans stuff is quite a bit different. That's why i was asking if I had gotten everything that could be disabled turn off.
