Fuel trim question
Old 12-13-2012, 08:27 PM
Drewmeyes88's Avatar
Default Fuel trim question
Ok hey guys I got my intake on now fixed the vacuum leak and idle is good. I'm still waiting on my PCM. So anyways I have my original PCM with a jet prograee and I was messing around looking at the logs it does and my stft is around 1.7x to -3. But my long term fuel trims are around 19-25 sometimes at idle then it'll drop to 10-15%? So I'm confused why would it be running lean? I do have every bolt on except under drive. So is it the programmer or the tune? I know I have exhaust leaks, can that throw it off? And does this mean it is really burning lean? Thanks guys
Old 12-13-2012, 09:55 PM
01ssreda4's Avatar
LTs could be saved from when you had the vacuum leak and haven't cleared themselves out yet??
Old 12-13-2012, 10:36 PM
I guess that's true I never unhooked my battery...I'll try that tomorrow. Thanks for the reply man
Old 12-14-2012, 02:57 PM
Old Geezer's Avatar
"I know I have exhaust leaks, can that throw it off? "
No doubt. Fix them.
Old 12-18-2012, 12:20 AM
Ok I'll fix them and I'll re check my fuel trims after I get my mail order tune
Quick Reply: Fuel trim question
